I want to programmatically password-protect the Settings->Apps->App Info screen (that has the uninstall, force close options). Is this possible? Something like what Mobile WatchDog is doing. I'm trying to find out how they do it.
i believe you would need to search for some kind of password protect app, but i am not sure you will find one that will specifically password protect just one part of your settings menu
Also if you want to be able to connect to the Forums from your Android device, be sure to check out the free Phandroid app in the Google Play Market. Cheers!!!!
