Apps Progress Dialog with SQLite Database
ondrovic
I have an app the on the first install it sets up an SQLite database. I would like to display a progress bar with this action is being done. Not quite sure which activity to put it in or how to go about doing it. I have a database activity which actually creates and inserts the tables into the database. In this app there is only 24 records that are being created. Right now it is loading the splash screen, then a blank black screen, which is where I would like to load the progress Dialog then the MainActivity is loaded
here is my database.class
Code:
package com.ondrovic.boombozzpassport;
import java.io.ByteArrayOutputStream;
import java.io.IOException;
import android.content.ContentValues;
import android.content.Context;
import android.database.sqlite.SQLiteDatabase;
import android.database.sqlite.SQLiteOpenHelper;
import android.graphics.Bitmap;
import android.graphics.BitmapFactory;
import android.provider.BaseColumns;
import android.util.Log;
public class Database extends SQLiteOpenHelper implements BaseColumns {
    private final static String DB_NAME = "boombozz.db";
    private final static int DB_VERSION = 1;
    static final String TABLE_BEERS = "beers";
    static final String COL_NAME = "name";
    static final String COL_BREWER = "brewer";
    static final String COL_ABV = "abv";
    static final String COL_RATE = "rating";
    static final String COL_BDESC = "breifdescription";
    static final String COL_FDESC = "fulldescription";
    static final String COL_TYPE = "type";
    static final String COL_PIC = "picture";
    private Context mContext;
    public Database(Context context) {
        super(context, DB_NAME, null, DB_VERSION);
        mContext = context;
    @Override
    public void onCreate(SQLiteDatabase db) {
        Log.w("onCreate : ","Creating Database Version: " + DB_VERSION);
        db.execSQL("CREATE TABLE beers (" + "_id INTEGER PRIMARY KEY, "
                + "name TEXT, " + "brewer TEXT, " + "abv REAL, "
                + "rating REAL, " + "breifdescription TEXT, "
                + "fulldescription TEXT, " + "type TEXT, " + "picture BLOB);");
        Log.w("onCreate","Inserting records into database");
        addBeer(db, "NAME 1", "BREWER 1", "TYPE 1", "BDESC 1", "FDESC 1", 0, 0, R.drawable.beer1);
        addBeer(db, "NAME 2", "BREWER 2", "TYPE 2", "BDESC 2", "FDESC 2", 0, 0, R.drawable.beer1);
        addBeer(db, "NAME 3", "BREWER 3", "TYPE 3", "BDESC 3", "FDESC 3", 0, 0, R.drawable.beer1);
        addBeer(db, "NAME 4", "BREWER 4", "TYPE 4", "BDESC 4", "FDESC 4", 0, 0, R.drawable.beer1);
        addBeer(db, "NAME 5", "BREWER 5", "TYPE 5", "BDESC 5", "FDESC 5", 0, 0, R.drawable.beer1);
        addBeer(db, "NAME 6", "BREWER 6", "TYPE 6", "BDESC 6", "FDESC 6", 0, 0, R.drawable.beer1);
        addBeer(db, "NAME 7", "BREWER 7", "TYPE 7", "BDESC 7", "FDESC 7", 0, 0, R.drawable.beer1);
        addBeer(db, "NAME 8", "BREWER 8", "TYPE 8", "BDESC 8", "FDESC 8", 0, 0, R.drawable.beer1);
        addBeer(db, "NAME 9", "BREWER 9", "TYPE 9", "BDESC 9", "FDESC 9", 0, 0, R.drawable.beer1);
        addBeer(db, "NAME 10", "BREWER 10", "TYPE 10", "BDESC 10", "FDESC 10", 0, 0, R.drawable.beer1);
        addBeer(db, "NAME 11", "BREWER 11", "TYPE 11", "BDESC 11", "FDESC 11", 0, 0, R.drawable.beer1);
        addBeer(db, "NAME 12", "BREWER 12", "TYPE 12", "BDESC 12", "FDESC 12", 0, 0, R.drawable.beer1);
        addBeer(db, "NAME 13", "BREWER 13", "TYPE 13", "BDESC 13", "FDESC 13", 0, 0, R.drawable.beer1);
        addBeer(db, "NAME 14", "BREWER 14", "TYPE 14", "BDESC 14", "FDESC 14", 0, 0, R.drawable.beer1);
        addBeer(db, "NAME 15", "BREWER 15", "TYPE 15", "BDESC 15", "FDESC 15", 0, 0, R.drawable.beer1);
        addBeer(db, "NAME 16", "BREWER 16", "TYPE 16", "BDESC 16", "FDESC 16", 0, 0, R.drawable.beer1);
        addBeer(db, "NAME 17", "BREWER 17", "TYPE 17", "BDESC 17", "FDESC 17", 0, 0, R.drawable.beer1);
        addBeer(db, "NAME 18", "BREWER 18", "TYPE 18", "BDESC 18", "FDESC 18", 0, 0, R.drawable.beer1);
        addBeer(db, "NAME 19", "BREWER 19", "TYPE 19", "BDESC 19", "FDESC 19", 0, 0, R.drawable.beer1);
        addBeer(db, "NAME 20", "BREWER 20", "TYPE 20", "BDESC 20", "FDESC 20", 0, 0, R.drawable.beer1);
        addBeer(db, "NAME 21", "BREWER 21", "TYPE 21", "BDESC 21", "FDESC 21", 0, 0, R.drawable.beer1);
        addBeer(db, "NAME 22", "BREWER 22", "TYPE 22", "BDESC 22", "FDESC 22", 0, 0, R.drawable.beer1);
        addBeer(db, "NAME 23", "BREWER 23", "TYPE 23", "BDESC 23", "FDESC 23", 0, 0, R.drawable.beer1);
        addBeer(db, "NAME 24", "BREWER 24", "TYPE 24", "BDESC 24", "FDESC 24", 0, 0, R.drawable.beer1);
    private void addBeer(SQLiteDatabase db, String name, String brewer,
            String type, String bdesc, String fdesc, int abv, int rate, int icon) {
        final ContentValues cv = new ContentValues();
        cv.put(COL_NAME, name);
        cv.put(COL_BREWER, brewer);
        cv.put(COL_TYPE, type);
        cv.put(COL_BDESC, bdesc);
        cv.put(COL_FDESC, fdesc);
        cv.put(COL_ABV, abv);
        cv.put(COL_RATE, rate);
        final Bitmap bitmap = BitmapFactory.decodeResource(mContext.getResources(), icon);
        writeBitmap(cv, COL_PIC, bitmap);
        db.insert(TABLE_BEERS, null, cv);
    static void writeBitmap(ContentValues cv, String name, Bitmap bitmap) {
        if (bitmap != null) {
            ByteArrayOutputStream out = new ByteArrayOutputStream();
            try {
                bitmap.compress(Bitmap.CompressFormat.PNG, 100, out);
                out.flush();
                out.close();
                cv.put(name, out.toByteArray());
            } catch (IOException e) {
                // Ignore
    @Override
    public void onUpgrade(SQLiteDatabase db, int oldVersion, int newVersion) {
        Log.w("onUpgrade", "Upgrading database from version: " + oldVersion
                + " to version: " + newVersion);
        db.execSQL("DROP TABLE IF EXISTS beers");
and here is my mainactivity.class
Code:
import java.util.concurrent.atomic.AtomicBoolean;
import com.pushlink.android.PushLink;
import android.app.Activity;
import android.content.Intent;
import android.database.Cursor;
import android.os.Bundle;
import android.view.LayoutInflater;
import android.view.View;
import android.view.ViewGroup;
import android.widget.AdapterView;
import android.widget.CursorAdapter;
import android.widget.ListView;
import android.widget.RatingBar;
import android.widget.TextView;
public class MainActivity extends Activity {
    AtomicBoolean isActive = new AtomicBoolean(true);
    BeerAdapter adapter = null;
    Cursor model = null;
    SQLiteDatabase db = null;
    /** Called when the activity is first created. */
    @Override
    public void onCreate(Bundle savedInstanceState) {
        PushLink.start(this, R.drawable.ic_launcher, 10, "269f78b325ebda1c", true);
        setContentView(R.layout.main);
        db = (new Database(this)).getWritableDatabase();
        ListView list = (ListView) findViewById(R.id.ListViewBeers);
        model = Beer.getAll(db);
        startManagingCursor(model);
        adapter = new BeerAdapter(model);
        list.setAdapter(adapter);
        list.setOnItemClickListener(onListClick);
    private AdapterView.OnItemClickListener onListClick = new AdapterView.OnItemClickListener() {
        @Override
        public void onItemClick(AdapterView<?> parent, View v, int pos, long id) {
            startActivity(new Intent(getApplicationContext(), BeerForm.class).putExtra(BeerForm.INTENT_BEER_ID, String.valueOf(id)));
    @Override
    public void onPause() {
        super.onPause();
        isActive.set(false);
    @Override
    public void onResume() {
        super.onResume();
        isActive.set(true);
    @Override
    public void onDestroy() {
        super.onDestroy();
        db.close();
    class BeerAdapter extends CursorAdapter {
        public BeerAdapter(Cursor c) {
            super(MainActivity.this, c);
        @Override
        public void bindView(View row, Context ctxt, Cursor c) {
            BeerWrapper wrapper = (BeerWrapper)row.getTag();
            wrapper.populateFrom(c);
        @Override
        public View newView(Context context, Cursor c, ViewGroup parent) {
            LayoutInflater inflater = getLayoutInflater();
            View row = inflater.inflate(R.layout.row, parent, false);
            BeerWrapper wrapper = new BeerWrapper(row);
            row.setTag(wrapper);
            return row;
    class BeerWrapper {
        private TextView name = null;
        private TextView brewer = null;
        private TextView bdesc = null;
        private RatingBar rating = null;
        private View row = null;
        BeerWrapper(View row) {
            this.row = row;
        void populateFrom(Cursor c) {
            getName().setText(c.getString(c.getColumnIndex("name")));
            getBrewer().setText(c.getString(c.getColumnIndex("brewer")));
            getDesc().setText(c.getString(c.getColumnIndex("breifdescription")));
            getRating().setRating(c.getFloat(c.getColumnIndex("rating")));
        TextView getName() {
            if (name == null) {
                name = (TextView)row.findViewById(R.id.TextViewRowName);
            return name;
        TextView getBrewer() {
            if (brewer == null) {
                brewer = (TextView)row.findViewById(R.id.TextViewRowBrewer);
            return brewer;
        TextView getDesc() {
            if (bdesc == null) {
                bdesc = (TextView)row.findViewById(R.id.TextViewRowBriefDescription);
            return bdesc;
        RatingBar getRating() {
            if (rating == null) {
                rating = (RatingBar)row.findViewById(R.id.RatingBarRatingSmall);
            return rating;
Thanks for the help and suggestions as always
