Add to your android phone this futuristic clock widget in high resolution (HD)Prometheus Analog Clock Widget HD!
Add to your android phone this futuristic analogue clock widget in high resolution (HD)
Here for you a beautiful clock widget.
The dominant color is blue with a crown flowing with the clock orange.
Prometheus is the title of a fable cothurnata Lucio Accio almost completely lost.
From the distant past projected into the future.
The widget can be customized in length and width. Recommend that you use full-screen
available on GOOGLE PLAY
Remember not to open the widget directly, but to install it as other widgets by holding down on the screen of your android phone.
Please read this important instructions:
This is a Prometheus analog clock widget, not a regular application. Unlike regular applications, widgets analog clock are placed on the home screen and offer useful (hopefully) information at a glance. In many cases, such as with this widget, you can press the widget and view additional, or more detailed, information.
other widget, theme, app HERE
