I have years of working practical experience with rechargeables of all types, and recalibration is rarely needed since Li-Ion/Polymer batteries have a microchip that monitors voltage, current, charge state, number of charges, etc. These are called "intelligent batteries" due to the integrated chip. Generally a recalibration is not required for at least a year of typical usage, and ONLY if the device does not recognize the state of charge properly.Plus a full dscharge/ recharge cycle once in a few months to recalibrate it.
That's correct as the microchip shuts off the charge current and prevents overcharge.There's nothing wrong with charging to 100% though and leaving it on the charger AFAIK
Actually the recommended charge level for storage is 40%, with normal temperature extremes - don't freeze it and don't overheat it. The reason is that Li-Ion uses a corrosive chemical reaction that is somewhat unstable, and storing at higher levels causes faster deterioration of the membranes in the cell structure. 40% is high enough that it will maintain a charge level long enough to prevent triggering of the safety circuit for up to a year. Li-Ion should never be stored for longer periods. If you intend to store for a long time, it's a good idea to recharge the battery once or twice a year to keep it stable and functional.The 80% would be if you were to keep it in storage for a long period of time(weeks/months), but I cant remember the technical reason at the moment.
Ideally you never want to run below about 30%, but we all know that's not practical for a phone or tablet. As I mentioned in my above posts, just try to keep it charged up whenever you can and the battery will last longer.How low should I let the battery get before charging?
Once of the great things about Li-Ion is that they work best with partial and top up charges. As long as the battery hits about 50% or more, you can unplug it and use it. Don't be afraid to unplug it when it hasn't reached a full charge. There are many times where you may need to give it a partial charge and run out the door...that's ok as long as you're not silly about it.How high should the be when I unplug it?
