Apps Property window not updating to new component?
Kalleyo
Hello, let me start by saying im completly new to AS, and im sure this is just some oversight on my behalf. However after i swapped to another Activity and wanted to edit some properties of the new activitys components, the property window just kept showing me an old component from the old activitiy window i just stopped using? Ive googled around a bit with no luck. I realise i can just add my changes in the text designer but id very much like to know what im doing wrong here if nothing else than atleast to learn :)
Thank you in advance and have a nice weekend!
Hi. Welcome to Android Forums.
Can you provide a screenshot to clarify what you're looking at?
This may not be what you're referring to, but I usually select the 'Autoscroll to/from source' options as shown below. This will display the relevant file contents automatically when you select it in the navigation pane.
I tried to enable Autoscroll, didnt help unfortunatly. However i did find out after some playing around, that my property window simply dont update at all anymore. Is it not supposed to refresh when i select a new component? Here is a screenshot where the selected component and the ID + Text that the property window shows does not match(got a text component marked yet it says its a button).
9
9
That's odd. My layout editor screen looks like this, and when I click on items in the component tree, it shows the correct properties in the properties window.
You see the icon on the top right of the properties window - two arrows going left and right. Click it. I think this syncs the component tree window and the properties window.
I belive those swap between extended property view, so no syncing it seems atleast not for me :/
