I needed an inexpensive Android tablet running Android 4.0 or later to use Droidplanner or Andropilot apps (the equivalent of Mission Planner for drones running on Android).
A key feature required for these apps is USB OTG or the ability to plug in a USB device to the tablet. Specifically the tablet must provide power to the USB device. The Proscan PLT-7035-C does indeed support USB OTG and provides power. The tablet does not come with an OTG cable. it comes with a power adapter and a micro USB cable. Note that the specs I read say it has a mini USB. This is not correct. It has micro USB.
Then came apps.
This tablet does not come with Google Play.
It has Aptoid (needs installation) and Amazon (needs installation) stores.
Finally got Andropilot and Droidplanner installed.
Unfortunately, Droidplanner has stopped.
Unfortunately, Andropilot has stopped.
ugh.
Talked with the Droidplanner developer and feeling was Google Play/Google Play Services might not be up to date. Installed Google Play Services update. No change in apps.
Next theory firmware update.
Found the Proscan website using the Online help icon on the tablet. Firmware found there.
Firmware update procedure... nada...
After lots of hunting I found what appears to be two ways. before you get excited, I have not been successful at updating the firmware but that may be a firmware issue not a procedure issue.
Here is what I found.
I found references to magic button sequences and found on the Proscan PLT7035C if you hold power and volume down (do not release) for a LONG time it will boot and show an android on his back with a red triangle. At that point briefly hold the power and tap volume up to get to the following menu:
android system recovery <3e>
note: if I had the tablet plugged into power this worked fine. Plugged into USb on the computer and I got a charge icon. You may have to try this with nothing plugged into the micro USB.
There you find the options:
Volume up/down move highlight
Power button to select
reboot system now
apply update from ADB
apply update from external storage
apply rkimage from external storage
apply update from cache
wipe data/factory reset
wipe cache partition
recovery from system backup
I also found that on other tablets you should have the update in the root folder of a formatted SD card so I downloaded the update from the proscan web site for the 7035C and put it on the SD card and renamed it udate.zip
Finding update package...
Opening update package...
verifying update package...
Installation aborted.
So I rebooted the tablet... it went IMMEDIATELY to the android on his back and would not boot.
bricked?
Well it turns out that Recovery system from backup actually works.
Rebooted and it was alive again.
that's when I discovered that booting with the SD card with update.zip in the root and the tablet will prompt:
Firmware Update
A update package file is found: '/mnt/external_sd/update.zip'.
Would you like to install the package?
I tap Install.
It flashes a message "now is to check..." too fast to copy down... then comes with
error
not a valid update package!
So it would appear that the firmware provided on the proscan web site is not a valid update package...
That's where I am...
I am thinking I may root the tablet and install Google Play etc...
Hope this helps someone...
Then came apps.
ugh.
reboot system now
bricked?
Firmware Update
I tap Install.
error
