stayboogy
Android Expert
Gingerbread 2.3.7 (CM 7.2 source)
i have a perfectly working sensors.so module for my device
the proximity works perfectly and quickly, and when using an app to test it, the values are as accurate as any other device and the response is flawless.
the proximity is also flawless when used in call if the phone is plugged into a power source,
however,
when the phone is not plugged into a power source and while in call, after the proximity kills the screen for more than a few seconds due to proximity detection, it will not wake back up without hitting the power key.
why would not being plugged into a power source produce this? also, since this has nothing to do with the sensor souce (as far as i'm aware and can tell) then it must be elsewhere. so where?
i've been all over then net and github looking for anything even remotely related and cannot find much at all.
any help or information appreciated.
however,
