Help Proximity sensor Issues
Hello i found out my N1 Proximity sensor have issue wen a install 2.3.3 my screen shutoff when i do call and stuck blank screen i have to remove the battery and put the back.
i download Elixir App and doing some test and Sensor only Say "NEAR" I put my hand on the screen still say Near...
Info:
Name: CM3602 Short Distance Proximity Sensor with Ambient Light Sensor
Vendor: Capella Microsystems
Version:1
Power: 0.5 mA
/etc/permissions
android.hardware.sensor.proximity.xml
android.hardware.sensor.light.xml
/system/lib
libssensorservice.so
Factory Code Nexus One
#*#0588#*#* Proximity sensor test (no work in my N1)
No Display Protector
Display Clean
can i restart the sensor?
can i disable Proximity in DIAL ?
do i need to take HTC Support N1?
where is the CM3602 on N1?
can i fix my self?
