before i updated to 2.1, The proximity sensor turns the touch screen off when your face touches the screen. after the updated, it does not seem to work anymore.
anyone has the same experience??
only if you have adw installed.
adw settings > system preferances > UNTICK SYSTEM PERSISTENT![]()
then try
SETTINGS>SOUND&DISPLAY>ORIENTATION
For your information, if you want to see if it's a hardware problem, at the lock screen instead of swiping push: menu > back > back > menu > back > menu > menu > back
then select "Service Tests" then Proximity Switch.
I went to services test, and found that my Proximity Sensor is OFF.
How do I ON it?
