Alright, I've been having this problem for the past few days, I saw a way to boost speed of 4g and/or bypass MetroPCS Proxies/throttling. My problem is none of this seems to work for the Huawei Premia.
I was told "Go to dialer and enter ##data# (##3262#) and a hidden menu would appear... it didn't.
Then I was told try ##*626* or something like that, no multimedia options, and yes I have my MSL and can make some edits just not that one.
Then I heard Use Apex Launcher. I got it, and found the hidden menu and could change everything except what needed to be changed. There is no "Multimedia" option in any of the segments, is there something I'm missing here? Cause I'm running out of ideas here.
My Plan is the unlimited LTE ($60 Plan) if that helps anything.
