O
Obould
Guest
Hi,
I am using a HTC Explorer with Android version 2.3.5 on it.
I am able to set proxy settings for my Wi-Fi connection through the advanced option.
However, the proxy setting only seems to work with the browser. Other apps are not able to sync or connect (I also use android facebook app, twitter app and gmail app).
Is there a solution or workaround for this issue (preferably without rooting the phone)?
Best regards,
Obould
Best regards,
Obould
