Help Pull down menu problem?
tgg1304
Member
when i get a text msg notification, normally i would use the pull down menu to go directly to the text but as of recently when i do that, it brings me to a completely blank text message. the "to" field is blank as well as the rest of it. i then have to exit the blank text and re enter thru the text msg icon on my home screen. any suggestions?
I'm using Handsent, along with ADW launcher and the ApeX 1.3.1 ROM and I'm running into the same issue occasionally. You are talking about when you drag the notification bar down and try to access the text that easy, correct. I just tried to recreate the issue by sending a text to myself, but no dice.
What text app, launcher, and ROM are you using?
Have you tried a reboot? Maybe that's why I couldn't recreate it today.
everything stock
