Purchase it from China
hhao
Hi, I purchase a HTC a3366, and bring it to USA. I can not associate this andriod to my google account.Also only can access htc store, but I only can see Chinses applications, can I change ios to the one used in USA?
How I can reinstall ios into this htc? Any one can help will be very apprecaited
Hhao
Hello hhao and welcome to AF. I think what you have is the HTC Wildfire. If so, you might want to check into the sub forum just for your device. There you should be able to gather information on the device and how you might modify it. Here is a link to that sub forum: HTC Wildfire - Android Forums
Good luck and enjoy the forums.
Hi hhao, welcome to the forums. As obriar has mentioned, the guys in the Widlfire forum should be able to help you.
As far as I'm aware though, isn't the use of Google services very limited in China/on chinese devices?
When you say ios? Do you mean the operating system on the phone, or iOS, the operating system used in iPhones, you want that on the handset?
