M
Member1771050
Guest
What's PushBack?
PushBack is a small tool for Windows operating system and it copies and backs up files from your internal and external memory via Android's ADB interface.
What can I use it for?
This tool is designed primarily for people whose device is affected by "MTP bug", that is, the situation where copying of large files from PC to phone suddenly interrupts. This is easily solvable by changing the USB cable, but not all of us have multiple USB cables at hand. Hence, this tool was made.
OK, so what can I do with this tool?
- List contents of your internal or external memory;
- Send one or multiple files to your internal or external memory;
- Backup default Camera folder from your internal or external memory;
- Backup ALL contents from your internal or external memory;
How do I install it?
Quite simple! First download it from HERE.
Unpack it anywhere, run either "Internal_PushBack.bat" or "External_PushBack.bat" depending on which memory you want to manipulate, select "Initial run" by pressing "0" to setup the folders (one time job!) and you're good to go
How to use it?
After initial run (remember, you do it only once) you will notice some folders are created (push, camera, camera_sd, fullbackup, fullbackup_sd).
Most important folder for us is "push" folder. Put in it everything you want to send (e.g. rom.zip, gapps.zip, etc.). In the rest of folders you will find your backed up files, according to their respective names.
Usage is simple; just press a number according to the action you desire and follow on-screen instructions, if any. For example, if you wish to send ROM to your device, you would put it in "push" folder and select number "2". Or if you wish to backup pictures and videos taken with Camera, you will press "3" and they will be stored in "camera" or "camera_sd" folder.
Help! It doesn't work!!!
Yes it does
If you never used ADB commands before, most probably your device isn't authorized yet. Check your phone, there should be a dialog asking you to allow USB debugging. Tick "Always allow from this computer" and select "OK". Now try to repeat you action and it should work. This authorization is also a one time job.
But how does it work?
As said above, it uses ADB interface. Basically, it issues "push" and "pull" commands depending on what you want to do. And some magic is involved
I hope you will like and use this tool.
This tool is based on and further adapted from the Gearloose ADB Manager, you can find it here:
http://forum.xda-developers.com/showthread.php?t=1177600
How to use it?
Yes it does
If you never used ADB commands before, most probably your device isn't authorized yet. Check your phone, there should be a dialog asking you to allow USB debugging. Tick "Always allow from this computer" and select "OK". Now try to repeat you action and it should work. This authorization is also a one time job.But how does it work?
I hope you will like and use this tool.This tool is based on and further adapted from the Gearloose ADB Manager, you can find it here:
