Help Put my phone's SD card into a Nook Color - will it work?
radsboy
Member
I have an HTC Eris, Android 2.1. I have a bunch of stuff on an SD card, mostly music and pictures.
If I insert that card in the Nook Color (borrowed from the library via my girlfriend the librarian, so it is not locked down in any way yet) will I be able to view those files etc? Without leaving any permanent evidence so she doesn't get in trouble at the library?
It's not a good idea to swap a card between devices. Each one will try to write to it.
You could plug both into your computer and copy from one to the other or one at a time to your computer, then to your Nook. I did a phone to phone transfer when I got my new phone, which doesn't have a sdcard.
If you're borrowing a NC, I'd pick up a sdcard or use a spare and copy whatever you want to that.
