Hi,
I have a problem with audio after the phone goes into stand-by (i.e. when the screens turns off). Then, the sound gets choppy or there is no sound at all anymore. This occures especially and is annoying in voip-applications like sipdroid. It makes phone-calls practically impossible because after aprox. 1 min the phone goes into stand-by and then the collocutor can't properly hear me and vice versa. I don't think that it's a special problem with sipdroid because I tried other voip apps and they show the same behaviour. It's not a WiFi problem, either - I checked in sipdroid that there is no packet loss.
My Device is a HTC Desire HD.
Does anyone alse have the same problem and is there a way to fix it?
Thanks in advance for your help!
Chris
Chris
