[Q] Complete Noob To Android and Galaxy - Been Using LG Chocolate
Intercrew
Hey guys! I recently purchased my galaxy from Telus and I must say it's a lovely device. Just a few cons for me is that it's a bit big and the volume rocker button is pretty loose. Other than that everything is just perfect.
This is the Telus version FYI
I just have a few questions if people could take their spare time to help out
1) How do you disable data usage? I tried pulling down the notification bar but there is no data off/on switch, only wifi.
2) If say I have data and wifi simultaneity on, what will exactly happen? Will wifi take over and automatically shut off the data?
3) Is there a way to automatically stop the use of data by having a restriction set up so for example once I hit 980mb, I won't be able to use the data unless I override and make it possible to continue using it. (Is watchdog a perfect app for this?)
4) The wifi/data icon on the status bar, what does the orange arrow going down mean and the other arrow facing up? The arrow facing downwards for my wifi keeps blinking orange/hang and goes back to grey. (Does it mean there something downloading in the background?)
5) What are some ways to improve the battery life of the phone?
6) Is there a way to remove "ME" on the contact list?
7) When I charge the phone through my laptop, it doesn't heat up but through the wall, the charging brick is rather hot. Is this safe?
8) To open the back cover, do you just put your nail/finger tip through the back hole and just use brute force to rip it off or is there something else? I feel like I'm gonna break the cover or the little edge/dimples on the sides of the cover where it fits into the back :l
9) Is there any way to change the brightness through maybe the status bar (moving fingers from right to left increases brightness and vise versa for left to right?) or maybe through notification bar?
10) Also should I have the sync icon on at all times in the notification bar?
11) Also is samsung kies needed? Whats the benefit of having it?
12) Is Samsung Kies needed?
13) I've read other threads about this too but I seem to be only getting one bar of wifi, and it's pretty slow for some reason. But when I go on 4g/lte it's amazingly fast - only problem is I won't be using the data network much. Any fix to this wifi issue? I've done the *#0011# and doesn't help at all.
14) Second last, every time I enter the gallery it seems to detect all my pc connected to my wifi. Any to way to stop this? Because I use to be able to delete photos but now I can' because a computer icon replaced the delete button.
15) I really appreciate the help guys, and last not but least, what are some useful/"needed/essential" apps to help or make life easier for the phone?
This is my first smartphone as I've been using my old lg chocolate for some time now and it just incredible how diverse the android os is but at the same time confusing and stressful to add what and such. I have so many things I want to do with the phone atm but stressful to figure out what to do in order lol.
I'm planning on rooting the phone after I save the contacts to my google.
Thanks everyone!
