Help [Q] Dial out options
johninga
I have lost the choice of using either Skype or Dialler when about to make a call . . I chose a default on one number, and that has now been applied to all. I cannot find a way to revert back to the choice . . can anyone there help . . .
You have to clear the default for your dialer. To do that go to Menu-->Settings-->Applications-->Manage Applications.
Go to the All Tab
Find "Dialer" click on it, scroll down till you find "Launch by default" and hit the Clear default button.
Now you should get the option when you dial a number to user either the dialer or Skype.
Enjoy.
