Apps [Q] help scripting sooo close
dcooterfrog
i am so close
I was able to manipulate a database using sqlite
and wrote the following script
Code:
#stuff
su
sqlite3 /data/data/com.nitrodesk.drois20.nitroid/databases/windroid.db <<SQL_ENTRY_TAG_1
    update table
    set boolean=0 ;
    commit;
    .exit
SQL_ENTRY_TAG_1
exit
and called it xxx.sh
i can navigate to the directory and cat the file
cat xxx.sh
shows properly
if I drop in to su and try to execute it I get
xxx.sh not found
chmod 777 xxx.sh
did not help
when I get it to work for sure
i will add it to the phone priortizer app and schedule it.
try this;
#./xxx.sh
Code:
$su
#./xxx.sh
 ./xxx.sh: permission denied
what was that supposed to do run or change permissions
#chmod 777 ./xxx.sh
resulted in o message
#ls -l shows
----rwxr-x system sdcard_rw 245 data time xxx.sh
why not rwxrwxrwx
Yes, you can
call sh to run it:
Code:
sh /sdcard/xxx.sh
I'll try that.
I solved my problem another way. I just added a database trigger to unchanged a change made by the program that I wanted to stop. Actually cleaner than my first idea. Which was to run a script every x hours.
Thanks
