Q:
If you have a stock Eris (non-rooted) that received the July 2010 OTA update, have you ever been in a voice call (since 17 July) which seemed to disconnect and then automatically reconnect without you doing anything?
If so, is your Radio firmware (Settings -> About phone -> Baseband version) 2.42.01.04.27?
This is not the same thing as a momentary drop-out in voice; instead, you actually get some indication in the UI that the call was dropped - and then the other caller re-appears without either party re-dialing. (Possibly also the speakerphone turns off if you were using it.)
Replies would be helpful; I'm trying to find out if this is a generic radio firmware issue, or something with the new Froyo (2.2) root ROMs.
eu1
Edit 9/14/2010 See post #35 or this XDA post for more details
eu1
