Completed:
Rooted
installed SDK manager
SuperAdmin perfectly configured
link2sd installed
experienced the cmd and ADB Shell and SU is working at 100%
Objective:
Create 2 partitions on SD card to store apps. ((Manually))
I've readed an interesting document to manually partition with "GNU Parted" which give's me access to the command "parted" and this is where I need you help. I couldn't find a topic in this forum that could explain how to install it...
Help:
How to Install GNU parted on Windows?
Is there any Other Manual way to create 2 partitions on SD (if possible - windows and Without card reader method)?
thank's in advance!
Drumans.
PS: Since im new on forums, I'll be making a research on this area in search for clues ; )
EDIT: Solved with SD USB card adapter and mini tools partition wizard
Rooted
link2sd installed
Objective:
Help:
thank's in advance!
Drumans.
