Apps (q) my application wont work unless i click on it from another launcher
Ive gotten pretty far on my own launcher.I used this code to make it so when you click home your launcher appears:
<activity
android:label="@string/app_name"
android:name=".yourclassname.java" >
<intent-filter >
<action android:name="android.intent.action.MAIN" />
<category
android:name="android.intent.category.HOME" />
<category
android:name="android.intent.category.DEFAULT" />
</intent-filter>
</activity>
This works but when i reboot and click on my launcher from the dialogue that pops up to select your launcher, it force closes. To fix this temporarily i just click on my app from a different launcher. Anyone have an idea on how to fix this? THANKS
If you actually have android:name=".yourclassname.java" in your AndroidManifest.xml, that will be the problem.
But instead of fixed that, I think you have a more fundamental structural problem in your AndroidManifest.xml.
You want the same activity to start in both cases right? Then you just have one acitivity with multiple sets of intent-filters.
Move the stuff between <intent-filter> ... </intent-fitler> to inside the activity with the MAIN and LAUNCHER intent-filter.
For example:
Code:
<activity
    android:name=".MyLauncherHomeActivity" >
  <intent-filter >
    <category android:name="android.intent.category.LAUNCHER" />
  </intent-filter>
  <intent-filter >
    <category android:name="android.intent.category.HOME" />
    <category android:name="android.intent.category.DEFAULT" />
  </intent-filter>
</activity>
For example:
Code:
<activity
  <intent-filter >
  </intent-filter>
  <intent-filter >
  </intent-filter>
</activity>
You are a very smart person.I thank you so much...it works like a charm.I love the quick replies..that's why i like this website more than xda
