[Q] Nexus 7C Hardware Buttons
Is the hardware buttons for the Nexus 7 ( power button + volume up and down button ) suppose to be a little bit loose? I've bought mine with 32GB 3G. The hardware buttons works perfectly fine but I can feel it moving a little when I do it up and down on the sides. Anyone has encounter this before? Thanks in advance.
No looseness in mine. Vol up/down has a positive click, as does the power button. I think from what you've said, you may have a QA problem.
Thanks for the reply. The power + volume buttons were solid when clicked. Only I could felt it move a little. Not a big deal anyway but just wanted to confirm. I'm noticed this alot in some other android phones like the Galaxy S2 and S3... The power and volume buttons are a little bit loose.
