Hi there, I think I may have messed the phone up a little, such as this MMI error message which comes up so I can't use speeddial, or any other # code for that matters, also I can't disable call forwarding, and a few other things.
This must have been the result of rooting, etc. Is there an easy way to get my phone back to how it was (basically how it would be straight from the manufacturer?), bearing in mind I have also flashed it 3 times?
Cheers.
Cheers.
