TheHybridTech
Posted this on XDA but have not go a response there. Figured I would try here to see if anyone has any answers...
Been trying to get OpenVPN to work properly and have not had much luck.
Here are my specs.
HTC Incredible
Virtuous v3.1.0
2.6.32-Hydra-ssuv-v05
OpenVPN binary has been installed. I have also install busybox and then softlinked ifconfig and route to the commands the same way CM6 has it.
I was able to get OpenVPN to work properly within CM6 without much hassle. I have found battery life and experience better for me with Virtuous ROM so I went back to it.
When I launch the connection to establish the VPN session it connects but I am not able to work within the network. I was not able to communicate even with the VPN server.
I ran a netcfg and discovered that tap0 was down. I brought it up but its routing table was empty. I filled it in and was able to communicate with the VPN server and my advertised networks. If I drop my VPN connection, tap0 goes down and the routing table is cleared.
The VPN server works. It works with my other boxes and worked with this phone under CM6.
Does anyone have any ideas on fixing this issue? It makes my job much easier and I really do not want to go back to CM6. Thank you and I look forward to an answer.
Here are my specs.
HTC Incredible
Virtuous v3.1.0
