Is it possible to flash the recovery while on the phone with this phone? I know you can with an app or terminal emulator on others. I haven't seen anything for this one.
TIA
When you say flash the recovery you mean to replace the current recovery with another recovery without the need of a computer? If so, then yes it can be done. I can tell you, but not till after you confirm that I am on the same page with you lol.
Yes. That's exactly what I mean. I'm out and about and have stock recovery. I want to flash something but can't Lol.
dd if=/sdcard/customrecovery.img of=/dev/block/mmcblk0p21
Its easy. Just need to know which partition holds the recovery. Thankfully, all our K2 variants holds the recovery on the same one, which is mmcblk0p21.
Place your custom recovery on the root of your internal sdcard so it will be quicker to type up the directory in the terminal emulator.
- Open the terminal emulator.
- Gain root, su.
- Type and enter:
Code:dd if=/sdcard/customrecovery.img of=/dev/block/mmcblk0p21
Once it is done you are good to go. You can do the same with the boot.img as well given the boot partition.
Worked like a charm. Just wanted to confirm I didn't mess anything up with your spot on information.![]()
I wouldn't steer you in the wrong direction lol. Glad it helped you out.
I know you wouldn't but I could easily screw it up. User error can be high with this one lol.![]()
cat /sdcard/customrecovery.img > /dev/block/mmcblk0p21
Also, to further expand your mind. If you reverse the given directories in either of those commands; it is how you can pull your boot.img, system.img, data.img, and so forth. Also known as a 'dump'.![]()
lol,
I have ridiculously small hands
"the whopper just make my hands look so tiny"
