A
Android Question
Guest
I have a wowpad with infotmic 0.1.6.5 (559) that no further charges than the green screen.
Now i have it update and now its working the only thing is that i get the message SORRY PROCESS SYSTEM IS NOT RESPONDING what is this mean an what can i do to fix this. I can go into menu but nothing ells work. When i did the update i see the next things.
1 instal linux
2 updating image android and finish.
3 burning file system and finish.
4 burning file system this isnt work (don,t now what this is)
5 remove sd and reboot.
when i reboot i get infotmic then green screen whit wowpad and then android loading and then its opens and i got the message sorry process is not responding,
HELP ME PLEASE
Cor
model p001 jutwania
android 2.2v2 5 4325
kernel 2.6.32.9
built frf85b
1 instal linux
HELP ME PLEASE
Cor
model p001 jutwania
kernel 2.6.32.9
built frf85b
