[Q] Wrong batterystat.bin: HD+cannot boot, how to fix?
  • Start date Start date
A
Android Question
Guest
Hi all,
It seems that I've made a stupid mistake when re-calibrating the battery for my HD+: my battery was not shown properly before, when there was 3500 mV it shows 1%, but I forced the calibration anyway, so I think now the machine regards 3500 mV as 1%. The thing is, after I turn it off, I'll never be able to turn it on again because it will only turn on when the battery is 5% or higher, which will never happen. Does know how I could change it back again please, like writing a standard batterystat.bin back into the machine again? The ROM is CM10.1.3 in eMMC btw. Thanks a lot in advance!
Bo
