ahdunno
IMPORTANT! If you're reading this, it may already be too late, but I advise anyone attempting to do any flashing to copy the flash_image binary to the /system/ bin/ directory before any flashing. It can save some headaches later if something goes wrong. If you're using a flash utility that reads the image from the sdcard, copy the stock image to /data/local/ as well. Then it's already there if you need to flash from calibration mode.
First and foremost, I want to make clear that unbricking of my Quattro would never have happened without the help from zimlokks and his original thead:
[Test][WIP!][Back to Stock!] Restore Phone via Calibration mode.
I recommend you go there and read it and thank him as well. It only takes a second to click on the Thanks button and it's just plain common courtesy for this and many other forums.
It may be confusing at 1st, as he and I posted back and forth while he helped me with this. As such, there has been a request for a more detailed guide. I have no intention of stealing his thunder and as I understand, he's talking of developing a script that would render this guide moot, and actually, I hope that materializes. So, here goes:
All the following was done in Windows 7 64bit in an Administrator account. I don't have Linux or Mac, so I have no idea on how to do it in those OS's.
Required downloads:
Quattro drivers from coolpadamericas.com
http://coolpadamericas.com/wp-content/uploads/2012/08/5860E_driver_setup.exe
Android SDK package (Select the appropriate version for either 32 or 64 bit Windows)
zimlokks' flash_image binary (Make sure to Thank him.)
killcmd's Quattro Stock Images
Boot, system and recovery images.
(Be sure to Thank him.)
Read this on XDA http://forum.xda-developers.com/showthread.php?t=1049102
Download Android Control app from XDA Dvelopers Forum (I'm a Noob and didn't know how to copy files to the phone via adb console. This helped me a lot. If you're good with the adb console you won't need this.)
#1 Install the Quattro drivers. I already had mine installed, so I'm not quite sure how it will go in Calibration mode.
Calibration mode is started by holding the volume down button on your phone while tapping the power button for a second or two. Plug the USB cable in and let Windows install the drivers.
#2 Extract the zip file SDK package. Once done, navigate to adt-bundle-windows...>sdk. There will be a folder named "platform-tools"
For ease in following this guide, copy that folder to you C:\ drive and rename it sdk.
#3 Extract the Android Control zip file. Copy the folder :AndroidControl" to your C:\ drive.
#4 Go to the sdk folder and copy adb.exe and fastboot.exe (Hold the Ctrl key as you select each, then right click and copy)
Paste those 2 files in the AndroidControl folder. (Overwrite the existing ones)
#5 For ease of use, copy zimlokks' flash_image binary to C:\ (root directory)
#6 Extract killcmd's Backup. Copy the recovery.img to C:\ (Ease of use again)
Important:
Pull the battery after trying a procedure, wait a bit and then replace your battery and try a normal boot.
This may hasten your results.
Note: If you try a procedure and it doesn't work, you can retry the procedure using an administrator "Command Prompt"
Do so by right clicking "Command Prompt" and select "Run as administrator" from the menu.
Also, some tips on the Android Control app:
In the "General" tab, there is a "Start server" button. DO NOT USE THIS!
It's important to start the daemon/server via the command console using the command
" adb devices ". The daemon/server in Android Control is outdated
In the "Advanced" menu, there is an option for "Shell". DO NOT USE!
Another tip on command prompt use:
Navigate to Command Prompt: Start> All Programs> Accessories Right click on "Command Prompt" and select "Pin to Start Menu"
This makes it easier to find and use. It'll be at the top left menu when you click your Window's start button.
Now, I'll list the procedures I tried. Note that ultimately it worked, but I'm not exactly clear on which did, as I didn't pull the battery and attempt to boot normally each time. I'm not willing to brick my phone again to determine which one worked.
*Procedure 1: **********************
Launch "Command Prompt"
Type cd c:\sdk
Type adb devices (This starts the adb daemon/server)
You should see this:
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
List of devices attached
Coolpad_5860E device
Type adb shell (Should see $)
Type su (Should see #)
Type mount -o rw,remount -t auto Coolpad_5860E /system
Note: If you previously placed flash_image in your phone's /system/bin, you can skip this next step and try flashing with the existing binary.
Now go to AndroidControl Folder (DO NOT CLOSE COMMAND PROMPT) and launch AndroidControl.exe
In the General tab, bottom left, you'll use "Copy to device"
In the top form, "Select file on PC...", browse to C:\ and select flash_image
In the second form type /system/bin/
Now click copy... Should see a success message.
Return to the command console
Type chmod 777 /system/bin/flash_image
If sucessful, your command string should be echoed.
If you get an error message, repeat the steps above using the "Run as Administrator option for Command Prompt.
Next, go to the "Flashing" tab in Android Control, top right, browse to C;\ and select recovery.img
Click "Flash Recovery Image" If the phone doesn't reboot, go to "General" tab, top right and click "Reboot Phone" (At one point, Android Control stopped responding for me. If this happens, right click on your task bar and start Task Manager. You can end the process and close Android Control from there.)
You should see activity on the phone.
Unplug the USB and remove battery, wait a bit, replace battery and try normal boot.
I'll post other procedures later. This is just a quick start, and I've got an hour in it already.
OK, about 3:30 AM, but continuing on 'cause I know I was on the edge of my seat awaiting responses from zimlokks when I was trying to flash my phone.
* Procedure 2 *************************
This assumes you already copied flash_image to /system/bin/ from procedure 1.
Start cmd console
Type cd c:\sdk
(If the daemon is already started you may not see all these lines. It is critical that you see the last line)
In the top form, "Select file on PC...", browse to C:\ and select recovery.img
In the second form type /data/local/
Type chmod 777 /data/local/recovery.img
Type flash_image recovery /data/local/recovery.img
(Should echo) flash_image recovery /data/local/recovery.img
You may have gotten an error message... ignore and continue
Type ^C (hold Ctrl key and type C... exits su mode
Then the line will read:
C:\sdk>
Type adb reboot
Phone should reboot, still hangs. Pull Battery, wait, reinstall, boot normal.
Again if it is still bricked, repeat the procedure running cmd prompt as administrator.
OK... Last procedure. This assumes flash_image and recovery.img have already been copied to the phone.
C:\sdk>adb shell
$ su
su
# mount -o rw,remount -t auto Coolpad_5860E /system
mount -o rw,remount -t auto Coolpad_5860E /system (echo)
# chmod 777 /system/bin/flash_image
chmod 777 /system/bin/flash_image (echo)
# chmod 777 /data/local/recovery.img
chmod 777 /data/local/recovery.img (echo)
# ^C (Ctrl + C keys)
C:\sdk>adb shell flash_image recovery /data/local/recovery.img
error writing recovery: Permission denied (I got this error... ignore)
C:\sdk>adb reboot
Phone should reboot.
Pull battery, wait, reinstall, try normal boot. It is at this point that my phone booted normally.
Note, however that in all previous attempts, I did not pull the battery and try booting normally,
so a prior procedure may work for you.
Again, if the last procedure has not fixed your phone, try running cmd prompt as administrator and repeat the commands.
Required downloads:
Important:
Type cd c:\sdk
Start cmd console
Type cd c:\sdk
C:\sdk>
Type adb reboot
C:\sdk>adb shell
$ su
su
C:\sdk>adb reboot
