dcooterfrog
ok I have some questions about rooting, recoveries, kernals etc.
the guides out there are all over the place
I think ideally what I want now is stock vc 'slimmed' and apps to sd. don't change the radio and keep amenra recovery
my ally was stock vc
i rooted it. did i I break OTAupdates.
i removed applications with Titanuim. did this break OTA?
I installed a custom recovery did this break OTA (i think so)
if ota is broken there is no reason not to keep going right. I will need to revert back to stock if I want LG official fro yo in a couple of months.
I have a brand new class 10 16 gb sd. can I "manually create an Apps to sd thought treminal commands.
everything I see says "if you rom supports it" enable it by having an properly partitioned card
if it just a sym link that can be done manually. right? what else is there.
there is a thread with "multi rom aps to sd" but vc is not listed.
i understand that there are 4 major components to a phone
radio
kernal
recovery
and 'rom'
can I use a different kernal with vc (gnm turbo)
is velocity 4 built on vc?
do I care if a rom is deodexed if I wont be theming. if I am not themeing is stock vc better if I add apps to sd and a better kernal
should i do all the way back to stock and start over...
radio
kernal
recovery
and 'rom'
