Question about 32 GB micro SD card
DillonM
Salesman at Radioshack somehow talked my mom into getting this phone. I hate it but I gotta live with it.
I'm planning on getting a new one just as soon as I get myself a job. But in the meantime I need this one to perform.
The phone came with the 2 GB card and I already had the 32 GB card from my Verizon phone. So I reformatted that before taking it out and switching. I plug it into the Venture and it reads it fine. But most apps I download doesn't give me the option to move it to the card. Some do. I have very few apps as a result because my phone is now almost out of internal storage. I have about 10 apps on the internal and 3 on the SD card. When I click on the apps from the "Manage apps" screen the "move to SD card" slot is greyed out.
Any reason as to why? Do I actually have to go to Virgin and buy a new SD card? I thought they were basically universal.
The problem is more likely that fewer and fewer apps support App2SD as it has been removed later versions of Android :(
I believe there are some workarounds for this, but you would need to root the phone - and that might affect your warranty. For more information, see the Rooting section of the sub-forum for you phone.
