AndroXplorer should be able to create shortcuts.
Harry
I was pretty sure AndroXplorer could create shortcuts but I haven't tried this yet ... because most times I'm using ES File Explorer and using it for shortcuts too.Don't suppose you know how? I have browsed their webpage but cant see.
So I've tried my AndroXplorer Pro, but the file manager stores any shortcuts only in an internal shortcuts folder, sorry for the misdirection !
So you might try ES as file manager, long press on the folder or file and choosing 'Shortcut' on the pop up menu will create a shortcut on the home screen.
Harry
ES isn't complicated and you'd have installed both ES and AndroXplorer ... or even more file managerI had picked Androxplorer as it seemed easier to understand
Is ES complicated?
Can I use both?
