Root question about droid overclock
VoidedSaint
Resident Ninja
i have set my scaling frequencies to Low Voltage at
1.35ghz 1.0 ghz 900 MHz 400 mhz
and my battery has gotten to 97
undervolting runs the processor at whatever clock speed you've set just with less voltage to the chip...as i understand it though, this doesn't necessarily translate to reduced battery drain. it may for some, and not for others.
also, you can set a profile so that if your device reaches a certain temp. it scales back the overclocking. I have mine set so that if it hits 107 deg, the cpu scaling goes back to stock. hopefully this will prevent me from frying my phone cause i don't have 500 bucks laying around to replace it, and i don't know if it would be claimable on my insurance.
you COULD claim the phone blew up in your ear, just cut your ear up a little bit and there ya go problem solved!
but on topic, i have a profile, im just not sure i have it set up the right way, i want to take pics of it and post it, however im at work and no signal in my office :(
