piedrafina
hi all, i have a question about reformatting my sd card. i used to use the card in question with a blackberry and would like to use it with my android now. when i plug the phone in to my computer, it shows up as two separate drives, one labeled blackberry and the one with the android files on it. so i figure i need to format it. but when i look at the phone storage options, the option to format the card under the sd card section is greyed out, but i can select it under the phone section.
just want to make sure that if i hit format under the phone section i am not going to mess something up.
