Help Question About Home Screen Weather/Clock Widget
unity04
I have the default HTC Sense Weather/Clock widget on my home screen and I have more than 1 location set up with my weather. I live in Canada, and automatically it displays the weather for 'Ontario'. I'd like to have it display the weather for my city 'Toronto', but for some reason it won't let me change what it displays and only displays Ontario. Now, Ontario is a big province, so the weather it displays doesn't always match my location. The weather widget is showing Ontario because it's using my location, however, the mylocation GPS feature is showing my entire province instead of where I actually am (City). I know in previous builds of Sense you're able to display and even enter manually, your city.
How do I get it to show what I want?
Thanks.
Press and hold it, drag it to the 'Edit' option and chose 'Current Location' instead - it'll then update when you go to a new place
EDIT: I see it's more an issue with your location than the widget. Sounds like it's how AccuWeather report the weather
