Root Question About Loki, Aboot, and Restoring
SwoRNLeaDejZ
Android Expert
OK, so I have a backup of stock C on my external. I flashed GT's kernel and the F aboot yesterday (love it so far). Wanted to restore C to check something and then restore my current backup after I'm done. Basically what I'm asking, if I restore my stock backup, will that replace the kernel and the aboot? Will it replace the kernel and not the aboot? Will it replace the aboot and not the kernel?
I need to know because I don't want to restore and have it replace the aboot with the C aboot, and not the kernel, because I'm sure that would cause huge problems. If it's an issue, I can restore, then flash the aboot before I reboot, but I need to know before I do anything.
Thanks in advance.
Here's an easy solution....
Restore the backup which will also restore the kernel you were using at the time of the backup. Before booting your phone after restoring the backup flash the F aboot. This will eliminate any doubts.
Just for the record. I restored to C, did what I had to do, then restored back to CM10 with Freedom Kernel... Long story short, when I got back to CM10, I had to reflash the kernel as it was no longer on my phone. Just rebooted back into recovery, flashed the kernel again, then the aboot.
Not sure why that happened, but it did :P
Yet another weird thing about the motion lol. On any phone I've ever owned the kernel that was backed up is fully restored. CWM recovery backs up boot.img(kernel) and recovery.img for sure.
It's beyond me why that happened to you.
Well glad things are working for you now... I hope. lol
Yeah :) everything is good. Just a note to everyone, if you restore a backup that had a custom kernel on it, reflash the kernel just to be sure (and aboot if you did the first time).
Thanks for the help GT, I appreciate it ;)
