Question about partitioning my SD card.
Status
Not open for further replies.
Vegamo
Ok here's the deal.
I used ROM Manager to Partition my SD card (I have clockwork recovery latest version),
I select 512 for EXT and 32 for Swap.
Phone reboots and when I check the file manager on my SD card, it reads my SD card has 7069M left.
? Help?
Is it partitioned? if so how can I make my apps Run off of it?
If it is, NOW WHAT? How do I use it to actually install Apps on it and Make my Phone faster?
Ok here's the deal.
? Help?
You could have at least mentioned what phone you have and original size of sd..
Assuming card is 8 Gb, partitioning seems to have been done..
Just use an A2SD+ supported ROM on your device and it should move all apps to ext itself.
Partitioning will not make a phone faster
Please do not create duplicate threads. Just bump your old one if your question was not originally answered.
Status
