Z
Zeratul1339
Guest
I partitioned my Myphone Storm using AParted because CWM currently doesn't support it. I partitioned it into two parts, first one as FAT32 with 4 GB, and second one as ext2 with 3.5 GB. I installed Mounts2SD to see if the partition is correct, but it shows that my external is not mounted. I opened my settings, and the storage says that I only have 4 GB of storage in my SD card. I can't partition my SD using Minitool because I don't have a memory card reader. Help me please.
