gothicnerd1033
Okay, Heres an interesting question.
Since USB 3.0 is becoming popular rapidly, And most likely 50% of us nowadays have USB 3.0 ports now.. If you plug your USB 2.0 HTC Evo 3D/V into a 3.0 port, Will it charge at USB 2.0 rates(500ma)? Or does it charge at the full 3.0 rate(900mah)? Does fastcharge enabled/disabled effect this in any way?
What about any USB device that is 2.0 in a 3.0 port? Is it allowed to pull the 900mah.. Or does it stick with the 2.0 500mah? Say your using a USB 2.0 4 port self powered hub(Not the kind with a power supply you plug into an AC outlet), plugged into a USB 3.0 port on your motherboard.. Does this mean the USB 2.0 hub can supply 900mah to its 4 ports.. or only 500mah?
Just figured Id ask, Since google doesnt return much.
