Root question about recovery?
taesamo
so i rooted with master root . and need to get some recovery/backup cwm or twrp which would be easier ....for a noob
twrp b the one to use and I would install the su that root master uses and go to play store and install that one and unstal the program that key something and I used rashr to flash twrp make sure u do a back up then use the l awe ROM its a good one in fact there all good happy flashing :)
They're both pretty easy to use, but each has it's own little quirks. What i find is that whichever one you start with is the one you stick with.
and should i update the supersu that comes with master root?
Ok im gonna make a thread that states read b4 rooting lol... It is not needed to root or flash a recovery to flash a rom hence y my roms title says works with stock device... I recommend only fastbooting to install rom and if u want also twrp if u dont want stock recovery... If u just want root get the zip from the super user site, fastboot to twrp and flash it... It all depends on what u want... I hope this helped and didnt confuse lol
what if i dont have a pc for the next 3 days ? can i still do recovery straight from device
Honestly i recommend waiting... Too many issues can arise from non pc rooting... But its sound like u already did it lol... As roadkill stated u can use rashr to flash recovery from device after u have root first...
i have 1 pc and a netbook but i am at my friends house
U can use any pc/netbook with a usb port and enough storage for the required files... If u download my stock device kit it includes everything u need as well as instructions...
when u open up rashr it says add zip so u add the twrp zip hope its on root of SD card then hit the flash it will rebot .I have done it this day over dozen times cause my PC not set up to do it that way
one question though when it ask to update su bianary it asks if i want to update normally or twrp or cwm which do i click
