Help Question about Texting - Please help!
ssr26
My husband and I both have moments. We both text quite a bit and for some reason, on his phone when you start typing a name in the "to" field of the text message, it does not give the option of choosing from matching contacts. But mine does. Is there a setting that I need to change? Anyone having the same issue?
Its not working either way. It just gives the number/letters you have typed but doesn't pull up a contact suggestion that you can then select.
