Question about Wifi Hotspots
exzibit7
I know that by using our phone as a Wifi Hotspot we can use its internet connection on our laptops.
But instead of using the phone's internet connection(2g/3g) can it retransmit another Wifi signal?
The reason I'm asking this is because the wifi signal strength from my router is very low in some areas of my house. So I was thinking can the phone use the wifi from my router and retransmit it so I get a better signal strength?
Is this possible?
Not possible. The Wifi antenna on your phone is receive-only. It cannot transmit it's own signal that it is receiving. If you have data turned on, then it can transmit-only the wireless data signal.
