Question Damaged SD card
wodzak
Recently i have taken my SD card out and now everytime i put it in my phone it says damaged sd card and i have formated and nothing happens. I have inserted it into my computer and it works fine. HELP!!!
Hi, and welcome to the forums! I don't have an answer for your SD card issue, but I would recommend posting this same question in the Android Lounge, a larger audience will see your issue there.
I would immediately save all data from the card to the computer. Then try another card (a known good one) on the phone to establish whether the problem follows the card or the phone.
If the problem follows the phone (the known good card does not work either), then I am sorry.
If the problem follows the card (i.e. the known good card works with the phone), then examine your card for any physical damage. If found, get a new card. Never use a damaged card. If no damage, try to re-insert the card a couple of times.
