Root [Question/Help] How to update To 2.3.6
zimlokks
Android Expert
ive looked but can seam to find how i dont want a cwm backup. i dont kno if its to much to ask or even if this question has been asked yes i searched bt only found backups. thanks in advance for the help!
If you're on metro you can download the update tool which is located on samsungs official admire page. Just search it up and click on manuals and downloads. You're going to need a computer to do this.
