Question on email sound
Hello and welcome aboard. Thanks for joining us here. :)
Depending on what device you have, you can find that option (disable) inside settings - sound or notification.
Also, you can check inside your device's support forum for tips and info on your device. You can choose your device model from the list here and join your device's area of support - where you'll find the other users of the same device love to hang out... and will be the best place to get device specific help.
Welcome to the AF, look around and enjoy. :beerglass:
Be sure to check out the sections dedicated to your Android device and your Carrier.
Also if you want to be able to connect to the Forums from your Android device, be sure to check out the free Phandroid app in the Google Play Market. Cheers!!!!
