horsecharles
Android Expert
Today i followed the Rooting & Flashing Step by Step Guide to the letter(cleaning phone & re-flashing stock zvd rom), but don't understand the why's:
1. Download rom(to external to conserve space).
2. Backup(logically to external card).
3- Using your volume keys to scroll and your power key to select, scroll down tand select "Wipe data/Factory Reset" then scroll to "Yes" and select.
4- Scroll down and select "Wipe Cache Partition" and then select "Yes"
5- Scroll down and select "Advanced" and select "Wipe Dalvik Cache" and then select "Yes" then scroll down and select "Go Back"
6- Sroll down and select "mounts and storage" then scroll down and select ONLY these 3 listed, "format data" and then select "Yes", then scroll down and select "format cache" and then select "Yes", then scroll down and select "format system" and then select "Yes". Then scroll down to and select "Go Back"
_________________________________________________________
But if anything goes wrong, one is up a creek with no paddles.
1. the wipes and formats leave one w/ no installed rom to reboot into while neither the computer or the LG Updater recognize phone(windows sees it as modem only). LGNPST sees but cannot read it.
2. the phone cannot read the sdcard, where the new rom or the previous backup could save the day:
cannot mount sdcard
cannot mount usbstorage
3. Formatting sdcard would lose everything.
The only lifesaver woulda been if things stored to internal, but with space at a premium....
CWM does list the entire structure of external sdcard under the internal one(since the directory structure is sdcard/_ExternalSD) but cannot access any of it.
cannot mount sdcard
