Root Question regarding automagisk on galaxy s5
Ok I wanna install automagsk on my s5 which is already rooted has SuperSU and Im not using any om or anything special like that, so I guess yu can say Im using stock rom? anyway according to this guide:
http://forum.xda-developers.com/apps/magisk/app-automagisk-automatically-disable-t3463475
"Note: You MUST have Magisk installed, with an unmodified system and Phh's Superuser. This is very important, AutoMagisk will NOT work otherwise."
Would my phone be considering unmodified? Or does unmodified mean not rooted? In which case how would anyones phone have or be running Super SU (which is what Im assuming "Phh's Superuser" is) if its unrooted?
The guides Ive seen on youtube suggest that if my phone is rooted I have to unroot it by wiping and putting it back to factory settings... then installs SuperSu Magisk, and Magisk.... so I have to unroot my phone, then reroot it? That makes no sense why not just install automagisk on the phone that already rooted since Im not running any custom roms/Os or something like that?
