Help Question regarding Notifications
sennis
I have the Samsung Galaxy S3 and i am wondering if there is a way to set up my notifications so that none of my programs will search (ex: facebook notificatons) unless my phone is connected to Wi-Fi?
Thanks
Hello sennis and welcome to our friendly community. :)
You mean you don't want notifications unless you're connected to WIFI? Sorry if I'm not following. :o
No that's not a setting.
What is the reason you don't want notifications unless on wifi? Is there a particular aspect of the notification system you NEED to supress specifically?
No there is not. It was just something i wanted to do and it is not really needed. I figured i would ask incase someone else had wanted the same thing and knew how to go about it.
What I mean is if there was a particular aspect you want surpressed rather than all aspects, I may be able to work out a solution.
Without understanding the need ( or requirement, or reason for wanting this) I cannot.
That's off topic, anyway. That isn't a double negative, he just missed a comma. A double negative is something like "I'm not doing nothing" which means "I am doing something".
Please, lets not try to pick holes in each other's posts - this is a forum, not an English exam ;)
You could always use Tasker (a paid app) to alter your settings based on whether or not you're connected to WiFi. But exactly what settings you want to toggle depends on what you're trying to achieve, like SURoot said. It is possible to disable auto-sync and background data use that way, but that would affect all apps, not just specific ones.
