Apps Question regarding tabs retaining fragment state
CodeSpace
Hi,
I'm trying to replicate an iOS app in Android. I have tab up an activity that holds 4 different fragments, and these are loaded using the .replace() method, depending on which tab is selected.
That's all fine. Working as intended.
My issue is that these 4 tabs also lead to other fragments (in my attempt to replicate iOS pushing view controllers within a tab). These fragments have to be native to the tab that they are loaded from. The problem is that if I load one of these fragments and then change tab the app tends to die rather quickly.
Does anyone have any recommendations about how to achieve what I'm after?
tl;dr: Here's a simple diagram in case my question isn't very clear:
MainActivity (Holds tabs (4 different tabs))
- Tab1 -> TabFragment1
- Tab2
- Tab3
- Tab4
So: TabFragment1 needs to be local to Tab1. If I load up TabFragment1 and switch to Tab2, and then switch back to Tab1, I would like to have TabFragment1 still active.
Thanks in advance!
