Teegunn
Android Expert
So I am still on 4.3 on my Note 3 because 4.4 borked the SD card permissions on android devices so I never updated my N3 to 4.4. I use my SD card a TON for many things like Music, Video, Pictures, App data, download folders, etc. My question is this- is there a bonafide workaround or fix for 4.4.4 that will allow the Note 4 to utilize my SD card and it's info the same way I can with my Note 3 that is on 4.3. Reading around the net, it doesn't seem there is a total fix for this issue yet. And I can't get any specific info on if 4.4.4 has fixed or made the SD card write and permissions better or worse than 4.4.2. Basically, if 4.4.4 borks my SD card usage, I might as well have a walled off device like Crapple.
